a/c dont work help
Old Apr 25, 2010 | 08:02 PM
91maroRS91's Avatar
Car: 1991 Camaro RS, 1987 Firebird
Engine: 305 TBI, 350 TPI
Transmission: 5 Speed, Auto
Axle/Gears: N/A someoone tell me
a/c dont work help
the a/c doesnt work in my 91 camaro with a 305 tbi. when i turn the heat or a/c on it doesnt even blow. also when i turn it on it anything it makes a kind of hissing nosie. can someone help me out tell me what it could possible be.
Old Apr 27, 2010 | 03:34 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Blown Blower ?
OK it sounds like the blower won’t run.
You want to find out if it’s the blower or something else.
Connect 12 volts directly to the blower motor connector at the housing.
Dose it run?
Happy Racing!
Make Noise, Turn Left, Repeat
Old Apr 27, 2010 | 03:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: a/c dont work help
Aside from the blower motor issue, it sounds like there's a vac leak. If so, under normal circumstance, the default would be defrost only.
BTW, if you'd like to know more about your gears, check the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 27, 2010 | 11:38 PM
91maroRS91's Avatar
also where may the blower motor be located
Old Apr 27, 2010 | 11:49 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
under the hood, on the firewall, passenger side. big black plastic thing. there should be a round part, with a 2 prong plug on it. thats youre blower motor.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
lakeffect2
Aug 23, 2015 08:44 AM
BikeFarm
Aug 11, 2015 11:35 PM
