To Dam Or Not To Dam
Old Apr 28, 2010 | 06:16 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
That is the question!!
After reading about overheating without an air dam, I called some yards, & I scored 1 today!!
I get home, clean it up, and hang it with the corner bolts, so it's only "on", but not fully secure. I stopped because--
(1) There is a large scoop running behind the grill. About a 1/4 circle shape.
(2) The air dam doesn't hang below the scoop, pretty much flush with the bottom of it.
So my Qs--
( a ) Do I keep the air dam, or is the scoop sufficient?
( b ) Does the scoop get attached with the edge on top of the chin spoiler, or should it attach to the bottom of the chin?
It's been over 2 yrs since I took it off for paint, & now I'm wondering if it's on correctly? For now, the scoop is bolted to the top of the chin.
Thanks for any help!!
Old Apr 28, 2010 | 06:26 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Re: To Dam Or Not To Dam
Put the air dam on. I made my own and it sits flush with the scoop. It made a huge difference.
Old Apr 28, 2010 | 06:38 PM
Car: '87 Camaro
Thanks for the advice & such a fast reply!!
Old Apr 28, 2010 | 06:45 PM
Stephen's Avatar
Car: 87 GTA
The air dams mount under the radiator wall. Not sure was "scoop" your referring to. But yes......Put the air dam on.
Old Apr 28, 2010 | 06:57 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
If you really dont want to yuo can always get a fog light grille and leave off the fogs. I did that... but I still have my air dam too.
But my car does run at like 160 on hot summer days with a 195 deg t-stat. But I have a 3-core AL radiator too... I dunno. I dont like the idea of experimenting with less cooling though.
Old Apr 28, 2010 | 07:03 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Dam-it!
Old Apr 28, 2010 | 07:15 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
i think the "scoop" he is referring to the plastic piece that clips onto the underside of the front bumper cover , maybe he's missing the little push in plugg like things .
Old Apr 28, 2010 | 08:02 PM
Car: '87 Camaro
Yea, the scoop thing under the bumper cover that bolts to the chin.
I have both grills to choose from, so I'm good there.
Dam will stay on. Good point on not taking chances. This Camaro didn't have the dam, & I never would've known it should if I didn't find TGO!!
Score another win for TGO!!!
Thanks everyone!! Greatly appreciated!!!
Old Apr 29, 2010 | 07:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's a pic that may give you the idea:
https://www.thirdgen.org/forums/atta...what-36mm2.jpg
JamesC
1992Z28!
Nov 19, 2015 07:33 AM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
krisner89
Oct 10, 2015 06:03 AM
tommy z-28
Oct 6, 2015 10:58 PM
steimel94
Sep 23, 2015 12:48 AM
