how hot is too hot
Old May 15, 2010 | 07:59 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
how hot is too hot
I just swaped from a 305TBI to a 355 TPI
temp is at about 200 when I turn the secondary fan on..
I get a little nervous when I see 220
So what is to hot for these cars..I removed all the A/c componants
Old May 15, 2010 | 09:24 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: how hot is too hot
well GM typically installs a 190 degree thermostat and a 220-230 fan kick on threshold... however, you say you removed your A/C... I'm not sure you may want to do some research on proper way of deleting your A/C both physically as well as electronically because I think your A/C may play part in how your first fan cycles... the majority of members here on TGO aren't using stock temperature control parameters... I myself am running a direct fan and a 180 degree stat... You will be surprised at the performance gains you will see...
Old May 17, 2010 | 12:26 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Radical Radiator
In addition to the above, due to the fact you removed the condenser, you have room for a thicker radiator.
You’ll be able to be koooool at the equator.
Happy Racing!
Why Did They Say I Was Speeding In The Pits? There’s No Speed Limit Sign.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
