Sngle or dual aftermarket fan
Old May 18, 2010 | 09:02 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Im not sure to go with a single 16" or go with a dual setup.I have an aluminum radiator to go with this set up.right now i have the factory dual set up in the car.I have 400sbc 501 cam,462 heads ported runnin 10-1 compression. th350 3200 stall converter 3.73 gears...any input would be great...
Old May 18, 2010 | 09:14 PM
Twin_Turbo's Avatar
Re: Sngle or dual aftermarket fan
2 13s have more core cover than a single 16...and this is the only way they will fit
Old May 18, 2010 | 10:10 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Is that your radiator, or someone you know? Ive got the same one and was wondering what you did for the upper rad mount? The stock one is too short to reach.
Old May 19, 2010 | 02:25 AM
Twin_Turbo's Avatar
yes it's mine and I made a custom top mount
Old May 19, 2010 | 08:18 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I run a single fan off a 1996(?) Lincoln Mark VIII. This thing move a ton of air. Most things I've read say its a little over 3500 CFM. I believe it. It does put a good draw on the alternator, but I dont think you will find an electric fan setup that moves more air. The shroud that comes with the fan is also very easy to modify to make it fit. I have a 31 X 19.5 inch aluminum radiator and this works perfectly. If you want, I can take pics to show you how easy it is to mount.
Old May 19, 2010 | 08:41 AM
buddiee's Avatar
Hey bro, i just bought an electric fan. I'd really like to see those pics.!
Old May 19, 2010 | 01:15 PM
built91Z28's Avatar
The fan shroud is almost a perfect box which makes it easy to mount. The only thing I did forget about is wether it would work on a stock radiator. Mine is a good bit bigger than stock and I actually cut out the stock lower radiator crossmember and made a new one that drops down an inch or two. I also had to make a mount up top. Mine isnt as nice as twinturbo's, but it works. Basically the fan comes with 4 tabs sticking out. I just cut them off and then I had a perfect box to work with. The size of the fan is about 18.75" by 22". I just took some 1" 90 degree aluminum and made brackets out of it to mount the fan. On the bottom the aluminum piece just slips inbetween the fan and the tabs I have to locate the radiator. You could probably bolt the fan to the stock radiator if the stock one has the aluminum tabs on top and bottom. Up top, it slips inbetween the bracket I made and the radiator. All I have to do is unplug the fan and take off the top mount and it slips right out. When you look at the shap of the blades you will see why this fan moves so much air.
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
scotrans am
Sep 5, 2015 04:26 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
