Coolant Can
Old May 24, 2010 | 11:06 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Coolant Can
Where could i purchase one of those clear or chrome catch cans or tubes that hold coolant for the radiator and i can bolt it right up?
Old May 25, 2010 | 12:02 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Coolant Can
Summit, Jegs, pretty much anyplace that sells a wide range of aftermarket parts. However, I doubt youll find one that "just bolts right up". It will most likely require some sort of fab work to install.
Old May 25, 2010 | 07:24 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Coolant Can
thanks, do you or anyone else have one and would take pictures of where you fab'd it up?
Old May 25, 2010 | 09:09 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Coolant Can
canton makes a bolt in one that looks sweet i have one just havent put it in yet http://www.cantonracingproducts.com/...ion&key=80-223
Old May 25, 2010 | 11:33 AM
travis401's Avatar
Car: 91 Camaro RS
Re: Coolant Can
Thats the first direct bolt in Ive seen.
Old May 25, 2010 | 11:54 AM
tom86iroc's Avatar
Car: 1986 iroc
Re: Coolant Can
the can is actually alittle smaller you might have to redrill some holes but i'll find out in acouple weeks
Old May 25, 2010 | 07:54 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Coolant Can
I don't really mind doing my own fab work, just wanted something to take alot less space up and be a bit cheaper like 10~30$
Old May 25, 2010 | 08:48 PM
icantdrive55's Avatar
Car: '89 RS vert
Engine: 305 TBI
Re: Coolant Can
Check with your local GM dealer for a factory replacement. I just bought a new puke tank for my '89 RS from a Chev dealer here in Cinti and it cost me $24 out the door. The parts guy originally told me they weren't in production any longer (not a big surprise there) but he did a search for warehouse supply and found 'em still in stock. I called him in the morning, and it was shipped to him overnight; I had it on the car the next day.
This was just last week, so I gotta think some are still available.
Good luck! -- Bubba
Old May 25, 2010 | 09:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Coolant Can
it bolts right in and is a really nice piece. Have it on my car.
Old May 25, 2010 | 11:04 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Coolant Can
thanks, probably get a new jug.. but i'd really like one of these small tubular catch cans, since it takes up ALOT LESS space.
Old May 27, 2010 | 01:34 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Coolant Can
Why not do the 4th gen coolant/battery tray, if you're looking for something that takes up less space? 5 bucks and one 12mm bolt to remove at the junkyard
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
