what do you think
Old May 26, 2010 | 09:07 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
what do you think
Iroc was having overheating issues changed rad ,stat,noticed fan not coming on changed out relays, and did a direct ground on fan temp switch so fan would run when engine turned on.
Ran no problem like this for 3 weeks temp guage read 190,sometimes shot up to 220 dont know why but today service engine light came on temp guage went to 230 and I had very little power from throttle response.
I would give it the gas and it was as if I was coasting.
I stopped the car openned the hood and saw that my coolant overflow container was above full..........where as before it was at min level.
After cooling down I restarted engine ran rough then smoothened itself out and coolant container was back down to min and service engine light went out..........anyone know what might be going on here
Old May 28, 2010 | 04:01 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: what do you think
is your serpentine belt tight? what condition is it in? wondering if its making adequate contact to spin your water pump. how old is the water pump?
Old May 28, 2010 | 04:41 PM
irock88's Avatar
could be the belt will have to check I only take the car out on sunny days and only put on about 600 miles a year if that,have had the car for 7 years and really havent done much to it other than oil changes and of course all items installed to try and resolve overheating
Will let you know thanks
Old May 28, 2010 | 06:10 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Try check it with another gage, the stock one may be off. I had my pegged at 260.
Old May 28, 2010 | 06:28 PM
irock88's Avatar
thanks I did check the gauge and it checks out,I also checked the the belt looks fine but I think Ill replace it seeing that I have owned the car for seven years and havent changed it and who knows when it was last installed.
I also decided to check the anti freeze level in the rad and found that the cap was loose, not all the way on..........strange I have driven the car for three weeks with no over heating problems until two days ago is it possible it came loose on its own or wait a minute I had a wheel alignment done two days ago and it started over heating when I left the shop.....................NAW couldnt possibly be
Im going to take it for a spin see what happens
Old May 28, 2010 | 09:43 PM
irock88's Avatar
Running cool now !
Thanks to all those who contributed to the thread
