Radiator fan cooling question
Old May 29, 2010 | 02:19 PM
blaznhot's Avatar
Car: 1992 Firebird
Engine: Stock 305 TBI
Transmission: auto / stock
Axle/Gears: Stock
Do the 92 Firebirds have a sensor to turn the radiator fan on at a certain temp? Mine comes on fine with the ac on, the temp guage is accurate but it will run up to 220 or so when sitting for a short while and I would think if it does have a sensor the fan would cut on at around 180. Thanks for any info!
Old May 30, 2010 | 07:26 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Radiator fan cooling question
facory fan(s) come on @220 or so you would need a temp switch to make it come on at a lower temp
Old May 30, 2010 | 11:57 AM
blaznhot's Avatar
Car: 1992 Firebird
Axle/Gears: Stock
Mine can sit until it starts to redline if I let it so I guess a new switch is needed. Thanks
Old May 30, 2010 | 12:43 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Fans from the factory won't turn on at 180°. Stock thermostat is 195° after all. You'd need a fan switch to turn it on cooler. I like the 200-185° fan switch (Hypertech). Although some like the 176-166° fan switch option. I find it too cold.
Stock fan on/off specs are in my sig.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
chazman
Aug 28, 2018 03:25 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
