running hot with proform water pump
Car: 1986 iroc
Engine: 350 .060 AFR HSR XFI280
Transmission: transgo 700r4
I recently installed an electric proform water pump along with AFR 190cc and the XFI280 cam waiting to get tuned. Car used to run about 160-180F on summer with stock heads/cam, now with this set up its going up to 220-230F.
What am trying to figure out is if the temp went higher because of the new heads/cam or the electric pump.
I have a new rad, 50/50 coolant, new 180* stat, no leaks, good airdam, single electric fan, I even installed an extra fan in front of rad and it helps somewhat but not enough,water pump is wired with a 30amp relay, no shorts.
Another thing I noticed when it gets to 220sh, I pulled over and carefully remove the rad cap but it has no pressure, am not sure if thats the way the pump works or something else?
I was thinking maybe I did something wrong or is it supposed to run that hot? Id really would like it to be around 160-180sh like before. If its the water pump causing this problem I might as well install a mec high flow water pump for my peace of mind.
Anybody has had any of this problems with a new electric water pump??
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: running hot with proform water pump
After driving the car there should be pressure. I would check the oil and make sure there is no coolant in it. It is possible for the intake manifold to leak into the lifter valley. Also check the radiator cap to make sure its good. If in doubt, replace it. Its cheap.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if you are not building pressure int eh system, something is wrong.
is the pump wired correctly and turning the right direction?
Car: 1986 iroc
Just checked oil and its a little low but it looks clean Yes sir, pump is wired correctly. the blue is positive, it even has the inline fuse from factory, so pump should be turning in the right direction.
I would have to get a radiator pressure tester and see if it has any internal leaks.
One more thing, last night went for a drive. It was cooler than in the day and car was actually running below 200* I guess its only good for night hunting but it kinda sucks!! I want to be able to drive it any time of the day with out having to glance at my temp gauge every 5 seconds..geezz
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
check your timing following GM setup procedure...
Car: 1986 iroc
Engine: 5.1 4bbl
10 degrees? double check your specs for your vehicle... I could have sworn that 0 degrees was for the LG4 .. 6 degrees for 305/350 and 10 for the v6
Car: 1986 iroc
stock is 6* on the 350's but since i have the aftermarket heads/cam 10* was were it felt happier, at 8* it would backfire a bit when hitting the throttle. so 10* is just for now til it gets tuned!
thanks for the replies any other ideas!!
You may want to try a lot more timing than that. My motor has a similar sized cam I think (236 @.050, .550 lift, 110 LSA) with Canfield 195cc heads. I run 18 degrees base timing. When I had it at 10 degrees, my headers were glowing within 10 minutes of having the car on. The combustion process was continuing in the exhaust system due to not enough timing.
Car: 1986 IROC
Engine: 355" TPI
If you cant get things to cool down a bit with timing adjustments and maybe a some fuel adjustments its probably the pump.
Engine: 5.1 4bbl
whoops... didn't factor that in... your cam didn't come with recommended timing?
Car: 1986 IROC
Engine: 355" TPI
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I'm having a very similar issue after putting in my new motor. The temps will continue to climb even at idle. Smogged the car the other day and it got VERY hot during the tests, we had a large shop fan and small one too trying to keep it cool. I have a becool 4 core rad, but I believe the stock fans are a weak point of the new setup. I've order a set of dual shrouded becool fans and when they arrive I will post any results. I just don't think the stock fans can pull enough air through the radiator to keep temps down when it's not moving at freeway speeds. I have a new delco pump and 50/50 mix as well. May consider running a 25% coolant/75% water mixture since we don't worry about low temps here in California, and see if that helps.
BTW my base timing is set at 6' base and the car runs well, passed california emissions with flying colors, so more timing isn't always a cure-all, you could have something else going on. I would definitely pressure check the system, mine builds pressure right away.
Will
Will
Car: 1986 iroc
Wow 18* base timing!! never gone that far in my car..but you might have a point because my brand new header gaskets didn't last long before they got literally roasted!! now i have that exhaust leak i need to take care of.
Car: 1986 iroc
OK, went and rented out a rad press tester. First, I tested my cooling system and thankfully it was holding pressure just fine. Second, I tested my one month old rad cap and the damn thing wouldn't hold pressure
IDK it might have been defective or some, and its the ones with the lever. So i put a cap out of my old truck, tested it and it passed.
I turned on car with pump off, let it get warm around 160sh then turned on pump and temp gauge went down in a hurry!! I will go drive around later on and I hope that's what my problem was. Can't never overlook the small stuff...right? built91Z28
IDK it might have been defective or some, and its the ones with the lever. So i put a cap out of my old truck, tested it and it passed.I turned on car with pump off, let it get warm around 160sh then turned on pump and temp gauge went down in a hurry!! I will go drive around later on and I hope that's what my problem was. Can't never overlook the small stuff...right? built91Z28
Glad it was something cheap and easy. 9 out of 10 times its the little things.
Car: 1986 iroc
Wanted to do a little update:
I installed a dual fan set up out of a newer third gen and it lowered the temp considerably. In hot days it stays at 160-180 and it colder days I have to turn off pump so it can reach normal operating temp since I have fans running as soon as car starts, so I definitely recommend this upgrade for single fan f-bodies, specially with high perfomance engines.
Now I need a higher amp alternator!! am running low volts with all this damn accesories...
eightsixseven
Dec 16, 2024 01:50 PM
theshackle
Mar 5, 2017 06:37 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
