What is the sensor called again? (Between spark plugs)
Old Jun 4, 2010 | 12:47 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
I forget what its called, Its not the one on top of the intake but the one between the spark plugs number 6 and 8 if I recall as well. How much do these run anyways?
I have been running my fans from my ac controls for a while now, so probably since I got it? I just realized that this sensor is good to have running.
Old Jun 4, 2010 | 07:31 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: What is the sensor called again? (Between spark plugs)
The parts store called it a fan switch. I just replaced mine(91Z). It's a switch that controls the passenger side fan when the temp gets high (around 250). Just be sure to get the correct one. Mine was $20.
Old Jun 4, 2010 | 07:57 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
$20? Damn, I paid $7.49 for a stock replacement.
Old Jun 4, 2010 | 08:54 PM
Carlos773's Avatar
Yep it was 9 bucks here with taxes already included. Thanks folks
Old Jun 5, 2010 | 01:45 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
They also make that switch in a version ( BWD brand ) that comes on at a earlier temperature.They cost more but are worth it if you want your fan on at a lower temp. Advanced/Kragens part numbers=
# TFS8 =220 on - 204 off, # TFS4 = 227 on - 211 off
# TFS1 = 238 on -222 off
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
