Water pump leaking
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
Water pump leaking
My water pump is leaking through that little hole under the water pump. Water pump going out?
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Water pump leaking
Yes. Its called a weep hole and will leak fluid when the bearing seal wears out.
Engine: 307
Axle/Gears: stock
Okay, so this would be my second one that is leaking through this hole. Time to just buy a new one.
Engine: gone
Transmission: gone
Axle/Gears: gone
wow sarah did you post a link to a website for non car water pumps? lol...
Yeah check into the warranties and stop buying remans!
Im waitin for mine to go out so I can install one of those high flow aluminum long life water pumps. just trying to get my money's worth out of my old pump first!
Engine: 307
Axle/Gears: stock
People i bought a high flow one.....works great.... now my radiator is leaking....go figure
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
