Cfm for a stock fan??
Old Jun 14, 2010 | 08:25 AM
jbarboza19's Avatar
Car: 86 Iroc
Axle/Gears: GU5 323
I have a 86 iroc, 305 tpi with a single fan which is comp controlled. I'm looking into replacing the radiator and fan in hopes to cool it down. Would anyone know the cfm on a stock single fan? The fan I'm looking into has a cfm of 2190 at 0 static pressure. Just wondering If its enough or more than enough to keep it cool. Thanks for any help.
Old Jun 14, 2010 | 08:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Cfm for a stock fan??
Should be - Advance/Autozone shows a replacement at ~1200 cfm. Another thing that helps tremendously is getting some aluminum roofing flashing (10ft roll at Home Depot $11), and making a shroud around the single fan so that more air is pulled from all over the radiator and not just the 14-16 inches infront of the fan. And the stock mount sets the fan about 2+ inches off the radiator, allowing it to draw around the radiator instead of thru it - homemade shroud helps alot with that.
Old Jun 16, 2010 | 01:16 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
i got some used fans of ls-1 and mounted them. solved my problems. they pull that air through great!
beastin91rs
Oct 9, 2015 07:38 AM
Genopsyde
Oct 7, 2015 08:35 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
