Cooling fan temp switch, wiring.
Old Jun 19, 2010 | 04:57 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
I have searched and not found exactly what I am looking for so....
I am finishing restoring my TA (not been on the road for 7 years) and was wiring the fan switch. I did buy Hypertech switch (should go on at ~180 and of at ~160). The TA has no ECM (carburated, old school setup). The fan did go on with the old engine (with the old fan switch) and it had no ecm eather.
The + wire was wired already but I did wire the switch as it was a ground (-). I did try the fan and when I put a ground to that wire its goes on.
Then I started the engine and let it warm up. At 220 F I did turn it off, the fan had not even started.
I am going to install a manual switch tomorow but I would like the other switch to work also.
Is there something I did wire wrong or it the Hypertech switch broken?
Thanks, Jon H.
Old Jun 19, 2010 | 05:58 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Cooling fan temp switch, wiring.
Did you check out this source? https://www.thirdgen.org/electric_co...pec_mod_single It may help
Old Jun 19, 2010 | 08:19 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
I dont see the answer there, am I correct that the switch should give me a minus (-)?
Old Jun 19, 2010 | 08:21 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I've tried alot of those switches in the head - and I gave up - even the Hypertech switch I bought never lasted more than 2 months, so I wouldn't be surprised.
I went with an aftermarket fan controller from Flex-a-lite over 3 years ago, and never looked back. It's worked great, fully adjustable, provisions for A/C, dual fans, manual switches for on and off, fully adjustable temp control, easy wiring job. Probes the radiator, so no getting covered in coolant mesing with it. I highly recommend one! The factory style head switches are a PITA, and never work.
Old Jun 19, 2010 | 08:22 PM
Car: 1992 RS
Engine: Carbed 350
When it reaches the set temp, it should provide a ground for the fan relay.
Old Jun 20, 2010 | 10:44 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Thank you all for your reply´s. I did put on a manual switch this morning and its working manually now. I dont know if there is a relay from the + (just used the existing wiring), how should a relay be wired if I have one?
Old Jun 26, 2010 | 08:28 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
I did go for a drive the other day, and with the fan turn on (manually) the temp did rise to 230 (then I shut the engine of). I did loose a little transmisson fluid and am wondering if a heat in the transmission could be letting my engine be so warm.
I was also wondering if my dual snorkel system (the vacum part not connected) could be taking an air that should cool the radiator (I have a summit aluminum radiator and the Trans has an auxilary oil cooler and the one in the radiator also connected).
There was no harm, the transmission works and the engine didnt overheat, I just want to solve the problem before it comes to that.
eightsixseven
Dec 16, 2024 01:50 PM
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
