89 iroc runs a little warm in traffic
Old Jun 20, 2010 | 01:00 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
it will hit 220 on the factory gauge in the 95 degree heat in stop and go traffic. Is this something i should be worried about?
Old Jun 20, 2010 | 01:44 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: 89 iroc runs a little warm in traffic
Its normal for a stock cooling system, don't worry about it.
Old Jun 20, 2010 | 03:07 PM
JSACRA's Avatar
Car: 89 IROC-Z
Engine: 6.2 LS3
Transmission: MN12 T56 GTO
mine started doing that after the headers were installed and i went out and bout me a jet performance fan switch it kicks on at 195 and off at 185 i believe, but that how they run a lil on the warn side
Old Jun 20, 2010 | 05:48 PM
irockidz28's Avatar
thats not to bad at all, if it is something that you are worried about or if it starts to creep up warmer...it is very easy to put the factory fan on a switch. I did mine and i am still using the factory relay and switch so it will still go on and off when it needs to or i can over ride it and turn it on when i want.
Old Jun 20, 2010 | 07:29 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
That's what mine runs at in the same temps.
Old Jun 20, 2010 | 09:28 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
i just wondered...i might get a different fan controller. Its not good for an engine to run over 210. makes the oil thin out....hard on the bearings and other moving parts. I guess a 180 thermostat is in the near future too
Old Jun 21, 2010 | 09:57 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Many cars run 210 and over with no negative effects.
I changed the fan temp setting in the ECM to get mine to run cooler.
zeitghaist
Aug 18, 2015 07:33 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
mustangman65_79
Aug 8, 2015 12:07 PM
