okay have a leak:no clue where from????...help
Old Jun 19, 2010 | 10:16 PM
jordanandrewkay's Avatar
Car: 1991 T/A GTA H/T
Axle/Gears: 3.23 Posi
okay so im drivin round yesterday and noticed some water coming from underneath my car....did not think twice about it because my A/C condensates like the rest of them. then realized my ac was not on. so its leaking very close to (or dripping down close to) the oil filter(drivers side).more towards the back of the engine bay. the leak is not visible from the top of the engine bay so its not hoses or anything like that. also another weird fact is that it does not smell like anti freeze. just water. and i have Anti freeze in my car..
Old Jun 19, 2010 | 10:44 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: okay have a leak:no clue where from????...help
Does your car have the adapter above the oil filter, that has 2 metal lines that coolant runs through? Maybe that?
Old Jun 19, 2010 | 10:45 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Your AC does not have to be on to dribble water. Sometimes, especially with older cars, the drain tube becomes at least partially clogged, and water collects inside your evaporator housing... then when the debris floats aside, the water finds its way out. You may want to inspect the drain tube, and maybe chase it with a stiff wire to clear it out.
Old Jun 19, 2010 | 11:09 PM
you would not happen to know what that adapter is for do you. and that sounds like it may be that just cause its on the opposite side.but i have not been able to get under her yet, probably wont get a chance to til monday. i was mainly looking for a cause of coolant being in that location. but thanks ternandes for that info i may do that anyway lol just in case.
Old Jun 19, 2010 | 11:12 PM
opposite side of the ac drain is what i meant.
Old Jun 20, 2010 | 06:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
sometimes when the waterpump gaskets leak, the water runs down the oil pan rail and to the filter, then drips off the filter. So it could be coming from a bunch of places. But is it just water, or coolant/antifreeze?
Old Jun 20, 2010 | 08:07 PM
well i can not answer for sur but dragging my finger through it revealed no smell but that 'water' smell. it was a little viscous but i assumed since its actually dripping around the rear of the engine to the right(no water actually runs off the filter) it might be collecting build up on the way down but idk... im gonna have to wait til tomorrow to look at it. it also does not leak (or pour out) while running just after i turn it off.
Old Jun 21, 2010 | 11:58 PM
bradley23150 was right. its a rubber hose connected to the steel lines. thanks for helping all.
RedLeader289
May 28, 2019 01:47 PM
92camaro350cci
Oct 14, 2015 09:29 AM
Jlanz55
Sep 9, 2015 09:09 AM
TheExaminer
Sep 6, 2015 11:40 PM
CORV3TT3
Aug 23, 2015 11:26 AM
