400SBC carbed overheating in hot weather
Old Aug 24, 2010 | 09:30 AM
  #51
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 400SBC carbed overheating in hot weather
Originally Posted by naf
The stock switches turn on kinda high for most people but as long as the radiator is not boiling over, it's really NOT overheating.
Old Aug 24, 2010 | 02:35 PM
  #52
S_Johnson's Avatar
Car: 87 T/A
Engine: 400SBC Carb'd
Transmission: T56, Kevlar clutch
Axle/Gears: 3.73 Yukon Duragrip posi
gotcha. I'm all for measuring it at the engine, but how do I actually hook it up? I'm assuming stock won't work, since the computer seemed to control at least some of it.
So what kind of aftermarket switch to I need? Thanks...
Old Aug 24, 2010 | 02:37 PM
  #53
S_Johnson's Avatar
Car: 87 T/A
Originally Posted by Apeiron
Oh, I know, but my 400 REALLY doesn't like it up there, I have a tendancy to run lean some times, which with the 9-1 compression, makes it cranky at 210ish. I've had problems with detonation before. I'm running 89 Octane fuel, and havn't had any problems, it just doesn't respond as well at those temps IMO.
Old Aug 24, 2010 | 03:20 PM
  #54
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The computer didn't control the fan in most models. The fan switch simply grounded the control leg of the fan relay using a single wire switch (ground through engine block). Most aftermarket two-wire temp switches will install in the stock location or can be installed in the water neck or manifold with an adapter (if needed).
Old Aug 25, 2010 | 06:12 PM
  #55
Awesome-X's Avatar
Car: 87 Camaro
I have that problem, too. My car can sit at 190 and run fine but as soon as it hits 200 it just starts to sound terrible...
Old Aug 25, 2010 | 07:41 PM
  #56
S_Johnson's Avatar
Car: 87 T/A
what compression ratio are you running, and with what fuel? Because if it's that bad, you might really have a problem...
Old Aug 26, 2010 | 08:33 PM
  #57
Awesome-X's Avatar
Car: 87 Camaro
I don't know and I run regular unleaded. I don't think its the gas, though I think its the heat. I can't really describe the sound...
Old Aug 26, 2010 | 08:41 PM
  #58
S_Johnson's Avatar
Car: 87 T/A
does it sound like a pinging noise? or a mechanical slapping sound? that would be detonation going off before the spark does. it's EXTREMELY hard on pistons...
Old Aug 26, 2010 | 09:01 PM
  #59
S_Johnson's Avatar
Car: 87 T/A
Ok guys, so here's a question, what's the fitting size for the head? alot of the summit sending units say "3/8-18 NPT" others say "1/8-20 NPT" and the second one says "inline style" sending unit???? Here are the links...
http://www.summitracing.com/parts/DER-16739/
http://www.summitracing.com/parts/DER-16721/
Thanks...
Old Aug 29, 2010 | 11:29 AM
  #60
S_Johnson's Avatar
Car: 87 T/A
ok... doesn't seem like this would be a hard question for someone who knew the answer...
Old Aug 29, 2010 | 08:22 PM
  #61
Awesome-X's Avatar
Car: 87 Camaro
It sounds like metal, like theres no oil in it or something.
Old Aug 29, 2010 | 09:48 PM
  #62
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Old heads are 1/2 NPT, newer ones are 3/8 NPT
Old Aug 30, 2010 | 08:45 AM
  #63
S_Johnson's Avatar
Car: 87 T/A
Like, a "clicking" matallic sound, or a "slapping/banging/pinging" metallic sound?
Old Aug 30, 2010 | 08:47 AM
  #64
S_Johnson's Avatar
Car: 87 T/A
Ok, so my heads are GM "487x" casting heads, I think they were a performance casting, (maybe vett?), but I have NO IDEA how old they are... I know that all of the sensors that went in my thirdgen (87) heads also fit in these, so they are the same as 87 heads, except for the valve cover bolts of course...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
1MeanZ
Dec 18, 2015 05:39 AM
rjcme
Sep 5, 2015 01:23 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
