both fans on sitting and runs hot
Old Jul 10, 2010 | 07:50 PM
triplec's Avatar
1992 B4C, runs cool at cruise, airdam in place, correct baffles, etc. But when sitting it will over heat. Both fans are on, but fast enough? 305 stock 5 speed runs temp at first mark on gauge ?180 at cruise even on 95 degree days. Creeps up to 240 when sitting. I think the cooling system is fine due to temp ate cruise, you cannot run a/c in town or will overheat at low speeds. Could this be due to retarded timing?
Old Jul 11, 2010 | 09:40 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: both fans on sitting and runs hot
Is it actually bubbling/gurgling when the guage reads the 240? Maybe the guage is off.
If coolant levels are fine, and your running a 50/50 mix, only other thing I can think of would be try replaceing the radiator cap - it's stupid thing I know, but can make a world of difference.
eightsixseven
Dec 16, 2024 01:50 PM
TheExaminer
Aug 26, 2015 04:59 PM
ezobens
Aug 19, 2015 10:29 PM
Leggman1
Aug 6, 2015 04:15 AM
