sensors, relay switch
Old Jul 18, 2010 | 12:37 AM
dalet's Avatar
Car: 1987 Trans Am
Engine: 5.0 Liter
I have an 87 305 trans am and need to know where the fan switch sensors and relay switch are located. I have a new electrical part that is supposed to be the part that I need to replace to make the fan turn on at somewhere around 220 degrees, but don't know for sure where to plug it in. The part has a couple of numbers on it, A103/00001 and 0004, made in Taiwan. It has four terminals inside of it. I have a single cooling fan. Can somebody clue me in on where it goes?
Dale
Old Jul 18, 2010 | 07:02 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: sensors, relay switch
no idea what you have, or where it would "plug in"
if you need the fans to come on earlier, you need a new fan switch, its located in the passengerside head, between cylinders 6 and 8 ( back 2). It has a 1 wire connector.
you can get them from various places, Jet, hypertech, ect.
Old Jul 18, 2010 | 11:45 AM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Not sure which fan switch setup you have as sometimes there are differences. As //<86TA>\\ said, you can check on the passenger head between cylinders 6 & 8 but you said you have a 4 wire sensor so I'm thinking the part you have might be what's shown about half way down in this post:
https://www.thirdgen.org/forums/cool...mp-switch.html
On my TPI 86 single fan setup, the relay for the fan is mounted next to the battery on the outer metal of the radiator support. If you look in this picture I used in another post for something else, you can see the fan relay on the lower right of the picture:
Old Jul 19, 2010 | 01:13 AM
dalet's Avatar
Car: 1987 Trans Am
Engine: 5.0 Liter
The fan relay on the lower right of the picture looks similar to the switch I've got. I don't remember seeing one in this same location on mine, but I'll look closer at it tomorrow. I appreciate the help and will post what I end up doing.
Dale
Old Jul 31, 2010 | 10:44 AM
snipzors's Avatar
Car: 87 iroc z
Engine: 5.0 TPI
Transmission: t5
Axle/Gears: stock
i see your fan connector looks like mine...plastic all kind of melted and such, as well as all my relay switches.. do you know if this is common, is it worth switching the ends.. or is it even possible??
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
