AC issues
Old Jul 28, 2010 | 08:45 PM
Tank91RS's Avatar
Car: 1991 Camaro RS
Engine: Carb 350ci bored .40
Axle/Gears: 2.73:1
AC issues
How should i go about figuring out what part
of my AC system is funky.
Symptoms.
Air blows through the vents SOOOO very softly just enough to hear it.
Not sure if it is cold air or hot.
My friend has a 84 camaro and he said his Blower Motor was dead.
Or something along those lines.
Any way to figure this out, rather then just replacing all the parts of my AC,
because some of the parts prices are just a little scary.
Old Jul 31, 2010 | 01:40 AM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
Re: AC issues
make sure that air is only coming out of one set of vents and not a mix of all of them.
when you move the vent switch around(top slider on the controls) you should hear some noises.
the noise is the mixer door moving around.
one out of two things is happening here(most likely) either your blower motor is going out, the mixer door isnt opperating properly. or your switch may possibly be going out.
i would start vy testing the door and the blower motor.
Old Aug 1, 2010 | 04:33 AM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
Re: AC issues
Ok, so i hear the doors opening,
So thats saying the blower motor is dead?
How would i go about replace one.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
