thermostat housing question
Old Jul 20, 2010 | 07:42 PM
twrudy's Avatar
Two 'sensors' are in/attached to my thermostat housing.
One of them is a coolant temperature sensor. What is the other one?
The engine in my car is pretty tore up...ironically, it runs pretty well. The previous owner shoved a 1989 L03 into a 1986 camaro and stuck a 1976 Q-jet on top.
In the process most sensors were deleted, and i have been unable to identify the sensor, or inlet/outlet, on the thermostat housing...it is more of a curiosity than in inconvience...i think.
Old Jul 20, 2010 | 09:40 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Re: thermostat housing question
I dunno, i do kno if u go to a chevy dealer and explain to the guy in parts the year and type of engine he can pull up a diagram of the engine with all labled parts and u just point it out and it will tell u on the list what it is.
Old Jul 20, 2010 | 10:23 PM
CamaroIROC88350's Avatar
It could be the intake air temp sensor?
Old Jul 20, 2010 | 10:42 PM
one92rs's Avatar
Car: SOLD!!!!!
one is prolly the coolant sensor and the other could be the fans sensor maybe. the intake air temp sensor is in the intake or air cleaner.
Old Jul 21, 2010 | 06:48 AM
twrudy's Avatar
Thanks for the replies.
The mystery has been resolved. One is the coolant temp sensor and the unknown 'sensor' is a vacuum switch. It appears that the switch was used to control some emissions hardware that no longer exists in my car.
Old Jul 21, 2010 | 09:03 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Weird - I didn't think any of the LO3's had any sensors in the Tstat housing - neither my 1990 or 1992 did.
Old Jul 21, 2010 | 09:10 AM
twrudy's Avatar
Yeah...the more I dig into this car, the more mysteries I find.
it is hard to say where that T-stat housing originally came from, but i am guessing that you are correct to assume that it did not come from the L03...VIN on block claims L03, but the carburetor and mechanical fan (yes, mechanical fan) tell me that this engine is a real piece of work.
Good times...
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
perZ
Aug 15, 2015 01:17 PM
