Wierd overheating pleaseeeee help
Old Jul 27, 2010 | 11:28 AM
DanniBoi91's Avatar
Car: 1987 Camaro SC
Engine: 355 V8
Transmission: TH350
Axle/Gears: Stock peg leg (for now)
I have a huge aluminum radiator with attactched overflow no a/c and an electric fan why is my car getting up to 210* with just a little bit of driving? plaese help thanks
okay i found out i dont have an air dam would this cause all this?
Old Jul 27, 2010 | 12:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Wierd overheating pleaseeeee help
If it's overheating on the highway it might. But, does your ground effects have any sort of air dam built in? Some of the SC cars had the air dam as a part of the ground effects.
Otherwise, see what temp the fan is coming on at, maybe try a 180 thermostat, try a new rad cap, check timing.
Old Jul 27, 2010 | 12:24 PM
DanniBoi91's Avatar
Car: 1987 Camaro SC
Engine: 355 V8
Transmission: TH350
just put 180 thermostat in and its a newer cap. timing im thinking is off but pretty darn close, my carb is also just set by ear so maybe thats causing it? the ground effects kinda look like they kinda would push it up but still could maybe use a air dam i dont know?
Old Jul 28, 2010 | 06:06 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If your car stays at an acceptable temp when idling or cruising around town casually, but heats up at higher speeds or on the freeway, then I would say YES you need an air dam if you don't have one. Lots of posts on the cooling forum if you need pictures. Use the search feature. Happy cooling!
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mud runner
Nov 2, 2015 07:30 PM
lanceflame44
Sep 25, 2015 12:28 PM
andy74
Sep 3, 2015 08:41 AM
