Cooling fan wiring
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
Cooling fan wiring
I just bought dual cooling fan setup from Dodge Stratus. They are two speed, both come on if I put a + to one wire, if I put a + to the other wire it just goes faster.
I did also buy a Flex-a-lite Variable Speed Controller (http://www.summitracing.com/parts/FLX-31165/).
This controler starts the fans on 60% an goes to 100% in if the temp goes up around 10 degrees.
I am just thinking if I should connect the controler to both wires (+) or if there is a better way.
Car: 86 T/A
Engine: ZZ383
Re: Cooling fan wiring
Well, I think I have figured it out, I will connect the positive from the controler just to the wire for the fans to got faster (there is not need in connecting the slow speed wire).
eightsixseven
Dec 16, 2024 01:50 PM
