Upper Hose Stiff
Old Aug 11, 2010 | 11:00 AM
usmc949803's Avatar
Car: 92 Camaro RS
Engine: 77' 350 bored 355 Holley carb
Transmission: Turbo 350
Upper Hose Stiff
92 rs with 77 350 w/carb. upper radiator hose is getting hard at times. not like when you push on it you feel the surge but totally hard. radiator was replaced in december. po had fan wired from temp sensor across headers. first nite taking car out radiator burst. found wire had burnt through shutting off fan. so put new radiator in and re-wired fan. put new water pump. new radiator cap. flushed system. now the hose problem. any ideas????? thanks
Old Aug 11, 2010 | 12:54 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Bursting With Information
Even tho the cap is new it might be defective.
Pressure test it.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Aug 11, 2010 | 02:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Upper Hose Stiff
I have no idea if this would make the hose stiff, but ...
When you swapped to carb, did you retain the serp belt system?
I ask because my thought was maybe you have the wrong water pump. If you kept the serp belt system, you need a reverse rotation water pump, if you went with any other belt system, you need a standard rotation pump.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
gord327
Sep 29, 2015 10:18 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
