FREEZE PUGS!!
Car: 1991 Trans Am GTA
Engine: 350 tpi
FREEZE PUGS!!
i got a 350 motor and i noticed the back freeze plug was leaking when i was cleaning it...i have never changed freeze plugs so how would i go about doing this..the motor is on a motor stand but all the internals are in there...and i dont know if i should replace them all or just the leaky one...the block number is 3970010 i believe the freeze plugs are brass and if they are would it be agood idea just to change one? and how do u do it thanks.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Freeze Plugs, Then Add Them To Your Favorite Beverage
To remove the plugs, use an awl, poke them and pop them out.
Install new ones with a hammer and plug driver.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Happy Racing!
Engine: 350 tpi
Re: Freeze Plugs, Then Add Them To Your Favorite Beverage
and do r recommend i do all 8 or just the one thats leaking? i believe they are the brass freeze plugs..and all this can be done with the internals still inside correct?
Transmission: 765R4
Yes you don’t have to remove parts.
If the other plugs look OK I would leave them.
The majority of engines never need their freeze plugs replaced.
Happy Racing!
Happy Racing!
Engine: 350 tpi
yeah thats what i was told but i noticed when i was cleaning the block that it had a leak from it its the one behind the block by the flex plate. so i just tap it til it turns sideways and pull it with pliers.
KamaroZ350
Dec 27, 2011 11:03 PM
Macgyver
Aug 12, 2001 04:37 PM
