Ever change a freeze plug with the motor in the car?
Old Aug 12, 2001 | 02:22 PM
Macgyver's Avatar
The block heater in the RS blew up, I'm spewing coolant faster than I can put it in.
Anyway, how do you remove and install a freeze plug?
This isn't a regular freeze plug however, it's got a block heater stuck in the middle of it..
Any ideas here?
Old Aug 12, 2001 | 03:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's no reason you can't change one in the car, as long as you can get to it. They even make those expandable rubber ones for situations where you can't get to it well enough to put a new one back in. I won't use one if I can help it, but it's better than no plug at all.
Which one is it?
ICON Motorsports
Old Aug 12, 2001 | 03:12 PM
Macgyver's Avatar
It's right above the oil filter.
Old Aug 12, 2001 | 03:18 PM
Macgyver's Avatar
How do you remove the freeze plugs?
Old Aug 12, 2001 | 03:28 PM
SS-84's Avatar
Car: 1992 RS
Transmission: 700R-4 when it works
I have never done one in the car. I usually just yank the motor and change all of them if one goes.
But to change them I drive them in with a punch, hold them, grab a pair of channel-locks and pull them out.
I have heard that somepeople drill them and use a screw and slide hammer them out.
LOBC-- SS-84
92 RS Heritage package with a 305 3" high-flow cat and pipe with a Dynomax 3" in dual 2 1/2" out.
84 El camino- 383 CID, Performer RPM, GMPP vortec heads, Holley 750 D.P.(0-4779c), Crane Energizer 274,Dual 3" Flowmaster 40 Series Exhaust, Turbo 350 (375b), TCI 2500 stall, Richmond 3.42 gears, PST Poly graphite Suspension bushings, PST steering linkage, PST springs, Monte SS sway bays, Wheels from a Third gen(does that count?)
Old Aug 12, 2001 | 04:37 PM
ede's Avatar
ede
drive it in to the water jacket then get a pry bar or screw driver behind it and pop it out, it's pretty easy after you get the hang of it. if you don't have room for the pry bar a pair of vise grips will do the same thing.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
slade5612
Aug 11, 2015 07:19 PM
mustangman65_79
Aug 8, 2015 01:18 AM
92projectcamaro
Aug 6, 2015 01:20 PM
