Installed Jegs Dual 12" Cooling Fans
Old Jul 24, 2010 | 11:42 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
So I just got done installing the new Jegs Fans. The part number is 555-52116. They look a lot better and work so much better than the single. They are actually almost a direct fit too! Only modification that had to be made was to the upper fan shroud. Took me only about 30 minutes for everything. I would definitely recommend these to anyone looking for an upgrade. They cost me just a little over $200.
Old Setup
New Setup
Old Aug 2, 2010 | 10:05 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Installed Jegs Dual 12" Cooling Fans
Looks nice. Definitely fills up the surface area of the radiator better. Texas with a single fan in August doesn't sound fun.
Old Aug 2, 2010 | 10:58 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Looks good. Let us know how well they work. I'm in the market for a new set of fans
Old Aug 2, 2010 | 11:19 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Old Aug 3, 2010 | 11:02 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
The return line on your FPR looks like its missing the hose clamp.
Fans look real nice.
Old Aug 8, 2010 | 08:41 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
thats cool i installed some 4th gen fans on my car and they work like a champ
Old Aug 9, 2010 | 11:15 AM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Yeah I went from the duals to 4th gen duals. What a difference! The wires were the same and everything. Just do some cutting to your upper fan support and you are set. Duals with a shroud are the way to go.
Old Aug 9, 2010 | 12:10 PM
skinny z's Avatar
Very timely post. I'm looking for new fans as well.
Old Aug 9, 2010 | 12:18 PM
Pairof91rss's Avatar
Car: 1991 B4C-1991 RS
Engine: L98 5.7 TPI-LB9 5.0 TB
Cant wait for an update as to how well they work...Need to do this upgrade myself
Old Aug 9, 2010 | 01:04 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Order the factory fans off of ebay. You can pick em up for less that $100. And they are factory quality.
Old Aug 9, 2010 | 01:31 PM
do you happen to have a pic of the 4th gen dual fan setup?
Old Aug 11, 2010 | 03:09 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
I'll take a pic tonight and post it.
Old Aug 11, 2010 | 06:07 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Here are some pics of the fans. The fan blades are identical. The motors look identical but I have heard the newer ones have higher amperage and the pn's are different.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
Leggman1
Aug 6, 2015 04:15 AM
