fan questions
Old Aug 17, 2010 | 12:52 PM
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
fan questions
The question I have is this, I have 92 GTA with twin fans witch one is the primary and witch is secondary? The fan that comes on with the ac is that the primary or secondary? The next question is when you ground the wire on the fan switch on the passenger side head the fan that runs is it the primary or the secondary? The last question is what controls the fan that doesn't come on when you ground the fan switch? Thanks for any help!!!!
Old Aug 17, 2010 | 01:34 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: fan questions
I think ...
that the primary is computer controlled and the computer gets it's temp info from the CTS located by the water neck - should come on around 210ish.
The secondary fan is controlled by the fan switch in the pass side head, it should come on at 230ish. Grounding this switch should make the secondary fan come on.
The A/C should also make the secondary fan run, regardless of any temp reading anywhere.
I don't have the dual fans, but this is what I understand from reading other posts here.
Old Aug 17, 2010 | 08:13 PM
Re: fan questions
Thanks for the help I checked the car when I got home and the driver side fan is bad.
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
