1982 - 1992 Radiator Support?
Old Aug 23, 2010 | 08:06 PM
howardsells2000's Avatar
Does anyone know of a company that sells Radiator Supports for a 1986 IROC Camaro. I found an old Classic Industries catalog that offered them but I called to order one and they said they are discontinued now. I searched the internet and couldn't find anything. Any advise will be appreciated.
Howard
Old Aug 23, 2010 | 08:23 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 1982 - 1992 Radiator Support?
Are you talking about the upper radiator support/ single electric fan bracket with the rubber mounting gaskets, or just the rubber pieces? I have a great condition bracket if that's what you want. Can send pics if you give me an email address
Old Aug 24, 2010 | 07:59 PM
I need the support that goes from fender to fender. It is welded to each fender. I don't know how to describe it. I thought it was called the radiator support. If you have one please let me know how much you want for it and a way to order it from you.
Old Aug 24, 2010 | 08:28 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Someone in your area may have a car they are parting out, or have already dismantled, but unless you give us some information about where you are that's going to be difficult. Got any wrecking yards near you?
Old Aug 24, 2010 | 08:39 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Looking around, I think it might be called the core support. Go to the body forum and do a search for core support and see what you find. Hope this helps. Oh, and also try asking for it in the parts wanted section . Good chance for finding more help there, Good luck
Old Aug 27, 2010 | 08:16 AM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
your talking about the radiator core support. i bent mine in a accident as well. i bought a whole other car that i used its for mine, as well as interior and fenders and such. 4 spot welds on each corner on top, 6 each side on the inside that weld the support to the frame rails and 8 on either horizontal side and vertical. not too hard to replace.
Old Aug 27, 2010 | 10:40 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Some places (like goodmark) list the upper tie bar which is the top bar only on the whole radiator support, but they never have it in stock.
armac
Sep 29, 2015 07:06 PM
steimel94
Sep 23, 2015 12:48 AM
Billyadams
Sep 22, 2015 08:25 AM
steimel94
Sep 20, 2015 12:46 PM
scottmoyer
Sep 20, 2015 11:54 AM
