Converting fan to computer control
Old Aug 26, 2010 | 02:32 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
I have an '85 with a single electric cooling fan. How would I go about making the ecm control it? My current ecm is from an '89 with dual fans so I assume I just need to wire the fan like it is the #2 fan?
Were the single electric fans multi speed?
Old Aug 26, 2010 | 03:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Converting fan to computer control
As I understand it ...
The primary fan was controlled by the ECM, the secondary fan was controlled by a fan switch in the pass side head (or by the A/C).
The ECM got it's temp reading from the CTS in the intake where the thermostat housing is. I assume that the ECM sent a ground to the primary fan relay when it sensed the right temp from the CTS.
But I never owned a dual fan car - this is all based on what I've read.
Old Aug 26, 2010 | 05:56 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
The stock single fans are One speed fans. Like newbie mentioned above, the primary fan is the ECM controlled one. That may be more reliable for you if you like the temperature it comes on at, and wiring it up is no problem. If you don't, burning a new chip to alter the fan turn on temp may or may not be easier for you than changing the stock single fan temp switch
Old Aug 26, 2010 | 06:24 PM
I have all of the chip burning and data logging burning a new chip for me would be much easier than messing with a mechanical switch.
Old Aug 26, 2010 | 07:10 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Oh yeah, If you've got that stuff and ability it sounds like it would be the best way to go. The CTS is definitely more reliable and easily accessed. Not sure how you would make sure the fan goes on anytime the AC is on, maybe not critical?
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
midge54
Jan 29, 2017 07:00 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
