HVAC control vacuum source?
Old Aug 30, 2004 | 02:37 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Not sure if this should go here...
Well In the swap to a stealth ram so long ago I ripped out a bunch of small vacuum lines in and around the engine bay thinking it'd be easy to replace them and that they were all for MAP, EGR and that kind of crap. Well I realized that at least one was for a source for the HVAC controls on the interior. I've got one small tube doing nothing in my engine bay and was wondering if any of you can snap a picture or draw up alittle diagram or hell, toss some sticks my way to show me where to run this tube so I can switch it off of just the defroster vents....
Old Sep 3, 2004 | 04:35 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
The tube for the A\C stuff should run to an oblong platic box near the top of the firewall near the wiper motor and the master cylinder.
Old Sep 9, 2004 | 12:20 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
...an oblong platic box near the top of the firewall near the wiper motor and the master cylinder.
Not on a '91. By then, GM had relocated the vacuum reservoir to underneath the driver's side battery tray/air filter/charcoal cannister area (exactly which one of those three is correct depends on the year and model). The newer style of vacuum reservoir looks like a 6" diameter plastic ball.
Old Sep 9, 2004 | 02:40 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
My 85 Caprice has the softball vac. resevoir, so it isn't that new.
Old Aug 24, 2010 | 10:27 AM
mikesanto70's Avatar
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
Re: HVAC control vacuum source?
so how do you tell where the problem with your line is, meaning, how do you find the vaccuum leak on a tube that long. Please help, my controls are all screwed up!!!!
Sorry to revive an old post, but it's relevant
Old Aug 24, 2010 | 10:28 AM
Engine: L99 L98
Nice car brother!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 24, 2010 | 11:54 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Thanks? I can't even remember posting this...
Are you heater controls stuck on defrost?
Old Aug 25, 2010 | 10:10 PM
Engine: L99 L98
they move from spot to spot but are not accurate, and if not in the *max* position, smoke starts to come out and a real raunchy smell, and when the selector is in the *off* position, the fan will still blow if you turn the **** to any of the 4 speeds and when you put the heat on the floor, it blows out defrost vents, WTF man? HELP!!!!
Old Aug 27, 2010 | 12:44 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Sounds like at the very least the fan switch/connector is toast. If it were my car I'd yank the control head out and inspect the vacuum lines at the head itself to make sure it's all in good condition right there. Maybe a botched stereo install at some point?
Old Aug 27, 2010 | 08:51 AM
Engine: L99 L98
I'm going to replace the whole control panel, then inspect/repair any vac. leaks. Stereo is the stocker believe it or not, never been out Thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
Bohemian
Aug 15, 2017 05:11 PM
Jlanz55
Sep 6, 2015 02:35 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
