Refrigerant Capacity?
Old Aug 31, 2010 | 09:26 PM
RyanEricW's Avatar
Wondering how much refrigerant I am going to need to charge my 92 RS 305TBI.
Going to buy this pump to use with my 20gal air compressor
http://cgi.ebay.com/ebaymotors/A-C-A...#ht_2630wt_939
this can of refrigerant (i have my 609)
http://refrigerantsales.net/shop/ind...3afd0ss46326v4
and my snapon manifold gauges
http://buy1.snapon.com/catalog/OBJECTS/55200/55150.JPG
Just need to know how many cans before I order O_o
I wont need to add any mineral oil, will I? I'm simply evacuating/vacuuming/recharging.
Doh $60 just for refrigerant....wow
Seems like I need 36oz's
http://napabeltshose.com/downloads/d...s&view=napa_hc
Old Sep 1, 2010 | 01:04 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Kool Skool
You’ll be using about 2½ pounds and you’ll want to end up with ~225 PSI at the high side, and ~27 PSI at the low side on an 80° day when the AC is running, engine ~1500 RPM.
If you don’t know if there’s enuff oil in the system add 4 ounces.
If you have no oil you will damage the compressor.
Too much oil will cause less cooling - the lesser of the 2 evils.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
Old Sep 1, 2010 | 06:10 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Refrigerant Capacity?
36 oz would be R-12. Autofrost uses 80% of the R-12 amount......80% of 2.25 lbs = 1.8 lbs. That is exactly 3 cans of Autofrost.
Vacuuming won't remove any mineral oil. You should be fine there.
Be prepared for some amazingly cold air conditioning. Autofrost cools about 10° colder than R-12. Faster initial cool down as well. You'll like it.
Hotrodboba400
Dec 10, 2019 07:07 PM
jrdturbo
Mar 31, 2016 02:58 PM
krisb410
Mid-Atlantic Region
Mar 11, 2016 09:21 PM
rubyred88
Sep 17, 2015 02:19 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
