trans fluid temp gauge?????
Old Sep 1, 2010 | 10:32 PM
johns88z28's Avatar
Car: 88 z28
Engine: 350 jegs crate motor
Transmission: 700r4 b&m transpak and megashifter
Axle/Gears: stock posi 3.23 disk brokes
our cars do not have these so where would i install a sending unit, to get a good reading, and to not leak! also oil temp sending also? i could try to do the oil one where the oil pressure switch is, would that give me an accurate temp reading tho?
Old Sep 1, 2010 | 11:25 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: trans fluid temp gauge?????
best place for the tranny temp sender is in the pan-
could braze a fitting into the side of a stock steel pan
or drill +tap an aluminum pan for the sender.
Could also put the sender in the "out"cooler line that
goes to the cooler-i have used both locations and they
gave about the same temp
For an engine oil temp sender,in the pan is good and
there is a port in the side of the block above the filter
that is a good location-that is where mine is,corvettes
used this location too.
the oil pressure gauge fitting at the back of the block
is not good for a temp gauge because though there is
pressure there,there is not really any flow past and
you will not get an accurate temp reading...
maroe624
Apr 16, 2017 08:29 AM
Reddeath210
Oct 6, 2015 08:20 AM
bamaboy0323
Aug 15, 2015 07:20 AM
Leggman1
Aug 6, 2015 04:15 AM
