Which fan is the primary one
Old Sep 9, 2010 | 03:06 PM
jac113's Avatar
Car: 1992 Camaro
Engine: LB9
Transmission: WC T5
Axle/Gears: 10 Bolt - 3.42
Hey guys,
just got my 305 running again after a head gasket job. When a friend of mine was looking at it he noticed that the passenger side fan came on first. It never got hot enough for the second to turn on but he was say that the driver side fan should come on first to cool the hot water coming in.
Can someone verify?
thx
Old Sep 10, 2010 | 10:52 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Which fan is the primary one
Driver side is the primary fan. Secondary is on the passenger side.
Old Sep 11, 2010 | 07:19 AM
asfalto's Avatar
Car: '88 camaro iroc-z
Transmission: TH 700 R4
Axle/Gears: 2.77 Borg Warner Axel
in my 88 iroc:
primary: driver side (ECM controlled)
secondary: pass side (temp switch controlled)
when the secondary fan starts it will kick the primary fan too if it's off (ecm failure / temp switch lower than stock / manual switch) so i think yoo have to check wires, relay and fan motor.
let us know!
Old Sep 11, 2010 | 11:03 AM
Midwest Muscle's Avatar
Edit: Wrong info in this original post - Corrected in a later reply after doing some additional troubleshooting!
My '92 Z28 (5.0) kicks the driver side on, but I've never seen the passenger one move. Turning on the A/C or the car getting to 238 degrees will set the driver side spinning.
The passenger just sits there doing nothing, and I believe it should be kicking on at 220 via ECM. I need to track that down. I don't trust one electric fan ... I like backup!
Mike
Last edited by Midwest Muscle; Sep 12, 2010 at 07:51 PM. Reason: Wrong info, found out after the post
Old Sep 11, 2010 | 12:57 PM
jac113's Avatar
Car: 1992 Camaro
Engine: LB9
Transmission: WC T5
Thanks all, I agree with u mike, your setup should be just like mine. I'm pretty sure my primary fan comes on when the a/c is on which seems to be backwards. I'm slowly learning about all the rigged up secrets that the previous owner did to the car. When I bought it the secondary fan was wired straight to ignition so it was always on. Gonna see if other fan comes on with a/c and if so I'm clipping wires and switching em.
Old Sep 12, 2010 | 07:56 PM
Okay, found out mine isn't doing exactly what I thought. I said the passenger side never came on ... That's because it's not gotten hot enough to.
My driver side is functioning as primary. It comes on (alone) when I turn the A/C on. It also comes on via ECM at 220. Verified this is the ECM side via the ALDL A-B jumper.
My passenger side does come on if the wire to the temp switch (between 6 & 8, passenger side head) is jumped to ground. So both fans work fine, as designed.
I had a lower temp secondary fan switch (215 vs 238), but just couldn't get the old one out. So I ended up doing something that I like even better ...
I ran a toggle switch inside the car, whereby I can ground that wire any time I want to. I will do that before the ECM-driven side comes on at 220. I prefer cooler to hotter.
And if I leave the switch alone (or just forget), the system will still function as designed ... Driver at 220, passenger at 238. So now I have control, and factory design(s) still function.
Mike
sheachopper
Jul 31, 2019 11:27 AM
thunder57
Nov 7, 2015 02:28 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
