Condensers - any better bolt-in ones out there?
Old Sep 13, 2010 | 05:12 PM
Firebat's Avatar
Just wondering if anyone knows of a condenser from another car or aftermarket condenser that will bolt in and is designed for a R-134a system. Looking for a condenser that is better performing than stock.
Old Sep 14, 2010 | 05:34 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Condensers - any better bolt-in ones out there?
Proliance makes one.
Part # 632310
6mm design (better than the stock tube & fin, not as good as parallel flow. But should fit and connect like stock)
Old Sep 19, 2010 | 02:25 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Reid, are you running that one on your car here in Houston? If so - did it help any?
Old Sep 21, 2010 | 11:58 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah someone had a thread on here about a better condenser. It might have been that proliance one. Im goign to upgrade this next summer. hopefully my systemwill work a little bit more efficiently.
Old Sep 26, 2010 | 10:30 PM
Car: 1989 GTA
I've thought about converting. But I'm still running the factory condenser. When I'm moving, the car will run cool enough that the added performance of the condenser would simply mean more compressor cycling.
Where the aftermarket condenser would benefit me is in stopped traffic. Long traffic lights where you sit through several of them. Gridlock highway traffic. It's during times like these, that my duct temps rise up. On the other hand, I wonder if it would be better to switch to a better fan setup than the stock duals. Either should help. Which one would be the most bang for the buck? I don't know.
Now if I were running R-134a, I would most definitely go to the better condenser setup. You're going to need every bit of help possible in weather like Houston's in that regard. R-134a runs hot for a given temperature/pressure point in the condenser. So stock condenser performance is already being used up before maximum cooling should/can occur.
Bubbajones_ya
Jul 6, 2024 08:32 PM
b4ccamaro
Jun 5, 2016 01:48 PM
deracer
Apr 11, 2016 12:04 AM
my86bird
Oct 23, 2015 12:20 PM
Street Lethal
Aug 13, 2015 08:28 PM
