heater coil bypass?
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
heater coil bypass?
i recently found out i have no heat. it looks like the guy that had it before me removed the coolant line from the core and ran it behind the coil and distributer. first just to be sure there is a fitting next to the ac unit coming through the firewall that is the heater coil inlet correct?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: heater coil bypass?
The two pipes coming from the firewall between the distributor and the blower box are the heater core.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If the heater core is bypassed, almost guaranteed it's leaking (most folks bypass when they leak), so might as well replace it before you reconnect, or else you might overheat and end up with a pass side floorboard full of coolant.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Yep. I can't think of a single reason why anybody would bother to bypass it other than the heater core leaking.
Car: 84 Z28 / 99 S-10 ZR2 4X4
Engine: STOCK CARB'D 305 WITH 350 HEADS
Axle/Gears: STOCK
I bypassed mine and there's enough heat from the engine bay/firewall to have heat....hahaha
RedLeader289
May 28, 2019 01:47 PM
