CT gauge reads full
Car: 87 Camaro
Engine: 305 LG4 (H)
CT gauge reads full
I just replaced the sender for the gauge (driver side head) and now the temperature reads completely full. Now I know if you ground a sensor it reads high, so does that mean the green wire is grounded somewhere in the system I can't see? When I unplug it the gauge goes to zero so I know the gauge itself works. Thanks in advance!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: CT gauge reads full
if you unplug it, and the guage does to zero, the sender is bad, even if its "new"
Car: 87 Camaro
Engine: 305 LG4 (H)
You're sure there couldn't be a wiring issue? I mean I planned on exchanging it tomorrow to be safe but I was still wondering if it could be anything else. Thanks
Car: 87 Camaro
Engine: 305 LG4 (H)
Exchanged the sensor and it works just fine now. Now I need the fan switch because I grounded the connector to the switch and it turned the fans on, but they don't come on on their own. Thanks for the help!
Ghettobird52
Jul 5, 2024 11:18 PM
ambainb
Apr 25, 2016 09:21 PM
86IROC112
Aug 17, 2015 02:00 PM
