84 non fan to fan conversion help needed
Old Nov 18, 2010 | 09:08 PM
chume1's Avatar
I have an 84 Z28 with a 305. I'm putting in a ZZ4. It has a serpentine belt system on it with no fan attached. So I need to add an electric fan... so my questions...
1. I read several posts that recommend a "corvette switch" for $20, can I "create" my own circuit using this temp sensor and harness to control an electric fan?
2. Can I keep my existing radiator? Its an aftermarket one
3. Should I use a single or double fan setup?
thanks in advance!
Old Nov 18, 2010 | 09:12 PM
mightymaro94's Avatar
Re: 84 non fan to fan conversion help needed
my 84 L69 had electric fan from the factory... your car doesnt? or was the engine swapped previous ..?
edit: scratch that... idk maybe it didnt
Old Nov 19, 2010 | 06:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Aftermarket electric fans usually come with ties like a ziptie that hold them to the radiator. Any aftermarket fan of your choosing & that fits would be fine - you'd probably want as fast a cfm fan as you can afford that fits well. I'd seriously look into an aftermarket controller, I have a Flex-a-Lite controller, it's really easy to wire, has provisions for manual on/off switches, is totally temperature adjustable, probes radiator for temp, and a great product - best $100 I ever spent!
Old Nov 20, 2010 | 06:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's a how-to for converting belt to dual OE electric:
https://www.thirdgen.org/forums/cool...electrics.html
JamesC
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
Leggman1
Aug 6, 2015 04:15 AM
