dumb question?
Old Nov 22, 2010 | 11:05 PM
Adrenaline91RS's Avatar
Car: 1991 Chevy Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 9-bolt Limited Slip
dumb question?
Getting a Aftermarket Edelbrock water pump for my car, right now i have the stock one, is there going to be any power difference from this??? and are they decent water pumps?
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: dumb question?
edelbrock is good...you may get a slight increase IIRC
Old Nov 22, 2010 | 11:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: dumb question?
You won't notice any difference.
Old Nov 23, 2010 | 01:20 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: dumb question?
nope. but youll have a name brand part.. it will only last 5 years tops.. i prefer stock ones.. or electric, cause with electric you can turn off your car, and cycle the electric fans and water pump cool it down faster after long drives.
Old Nov 28, 2010 | 04:37 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: dumb question?
And you know this how?
Old Nov 29, 2010 | 12:05 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: dumb question?
my edelbrock pump is still going strong 12yrs after i
installed it-these pumps are made in the USA and the
bearing and seals are the same as used in the original
GM pumps,so they could easily last 20yrs or more
These pumps have an oversized impeller and pump a
little more water than the originals,but i did not notice
any difference in cooling-might help in a marginal
situation though.
Old Nov 29, 2010 | 02:16 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: dumb question?
I have heard nothing but good things about the edelbrock pumps, im waiting for my pump to go out and to get one.
Electric water pumps have short lives and should be avoided with street cars.
To get full effect of high flow pumps also use a high flow stat. they claim the pump helps stop crud buildup on the sides of your water ports due to the volume and pressure of water going.
you should feel no HP difference with a water pump change. Unless it is electric, then it will have a little less engine drag. if I was going to put an electric on, then id carry a spare. along witha spare relay for it too.
Old Nov 29, 2010 | 07:05 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: dumb question?
You can have more drag at times with an electric pump, due to the inefficiencies in the mechanical->electrical->mechanical conversion processes.
A Meziere HD street pump is rated for something like 3500+ hours of continuous use. Running it for 2 hours a day every day, that's almost 5 years.
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
