temperature gauge problem
Old Nov 29, 2010 | 08:12 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
my temperature gauge isnt working, how can i tell if the gauge is bad? when i crank on the car the gauge pegs its self but the gauge doesnt move as the car heats up, any help here would help!!
Old Nov 29, 2010 | 08:32 PM
1986350's Avatar
Car: 1985 Pontiac trans am
Engine: 350 4bbl
Transmission: 5-Speed
Axle/Gears: limited slip
Re: temperature gauge problem
mines having the same problom but i cant get the old sending unit out, I think it fused itself to the aluminum but did you check your sending unit and/or the wires going to the sending unit. BTW i have a carbed 305
Old Nov 29, 2010 | 08:43 PM
Engine: L31 350
mines a 2.8, i havent checked the wireing yet, i need too, its bugging me not knowing how hot my car is running
Old Nov 29, 2010 | 10:51 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Ground the wire on the sensor w/the ing on.If the needle moves the gauge should be fine.I think thats basically what happens while your cranking the eng, but double check it anyway.
Its probably the sensor though.
Old Nov 30, 2010 | 08:37 AM
Engine: L31 350
are the sensors hard to change?
Old Nov 30, 2010 | 09:31 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Had the same problem,I cut the old wire end off and put a new one on and everything works fine.Probably the end!
Ghettobird52
Jul 5, 2024 11:18 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
