coolant fan switch
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
coolant fan switch
I've been searching around and can't seem to find a low temp coolant fan switch. I'd like for it to thread into the head, kick on around 180deg, and shut off around 160/165. Any one know of an AcDelco, echlin or other type? I don't want an adjustable.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: coolant fan switch
Heres some listings, not as cool as you were looking for tho. Use the search feature for lots more info
https://www.thirdgen.org/forums/cool...ernatives.html
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
yeah I saw those, but they won't work for my app. Its going on a non-computer controlled car.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I vaguely remember reading somewhere , maybe another forum?, something about a fan switch for some year Corvette that would fit and work at a lower temp? No idea how much cooler, but if you run out of ideas try checking that out. Who knows??
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Hey here's that corvette switch I was remembering, its the second post right under the other guys. Lots lower, IDK if you can do any better?
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
I needed something a bit colder. I just ordered a probe type from derale. comes on at 180, turns off at 170.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Not exactly what your asking, but a fair compromise.
http://rodneydickman.com/catalog/pro...roducts_id=233
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I bought mine from a corvette online sales place. It was 195/185 I believe, which is what you need for a 170* thermostat. I want to say it was midwest corvette, or something along those lines
Here we go
http://www.mamotorworks.com/corvette?frame=1.944
They say on at 200, off at 185. You gotta realize, there's some margin of error in those numbers. You need your t-stat to be WIDE OPEN, long before your fan comes on, or else you'll get stuck with your fan running all the time to try to keep it cold enough to close the t-stat (a hopeless endeavour).
Plus, you don't actually want to run any cooler then 170* or so, or you'll just sludge up your oil really fast.
Here we go
Car: 91 Trans am
that happened to me with the 195/185 on/off, combined with the 180 t-stat, the fan would run all the time once on.I went with the 210/200 and 180 t-stat. Recycled the 195/185 in a car of a friend that had a 160 or 170 t-stat.
Car: 87 T-Top GTA
OMG guys, very simple.....
Hypertech Cool Fan Switch...
#4026 On at 176* Off at 166* You will need to change out stock t-stat and R/R with lower stat, (160*-170*)
You could even try Ebay or Summit too see whats out there for our cars!
Car: 1982 Trans-Am
OMG to you too chat monkey - that hypertech switch wouldn't work. Your fan would be running all the time (on the highway, etc). It'd never switch off, because it could never cool the engine below the full opening point of the thermostat.
You could use that if you pulled your thermostat perhaps, and had a great cooling system, but why bother? Running your engine that cold just makes you sludge up your oil faster, and burn more fuel because it's always too cold. The whole "colder is better" trend can be taken too far.... A cold air intake is fine, but don't run your engine below a reasonable operating temperature.
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
My car is running fine with the 160 deg thermostat and a 170off/180on switch. Its a derale that most places have to order, never on the shelf. I was just looking to find a stock application to purchase at a local auto part store-for quick replacement.
As for my oil sludging up, maybe on regular oil. I haven't had that problem with synthetic. Fuel mileage, I haven't seen a loss. Then again, this whole situation is for another car, a 1960's Ford Ranchero. 351w with a 2 barrel. Its getting hot, 190-200. The car doesn't run well at that temp. It runs best at 165-175.
So, thanks to everyone. Problem has been solved.
Car: 87 T-Top GTA
[quote=Sonix;4578402]OMG to you too chat monkey - that hypertech switch wouldn't work. Your fan would be running all the time (on the highway, etc). It'd never switch off.....quote]
The org poster asked for "a low temp coolant fan switch. I'd like for it to thread into the head, kick on around 180deg, and shut off around 160/165."-monkihead. And thats pretty much spec with the Hypertech's 4026. Thats what he/she is asking for, and thats my awnser.
Try paying attention to the needs of others!
BTW, the fan does turn off on highway.
henryd3,
I am still interested in the 91 Camaro reversing switch part number 20614880.
You quoted $20 shipped.
Would you please contact me at:
jeffrey.sturm@gmail.com
Thanks much
Thanks much
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
