Heating / Air problem here!
Old Nov 28, 2010 | 11:36 PM
Demo77's Avatar
Car: 1992 Firebird Formula
Engine: 305 TBI
Axle/Gears: 10 bolt 2.73 (Upgrading)
Issues/problems:
- While driving, heat is not all that hot until I stop. Car reaches higher temps while idle so I presume this is why it gets hotter but I do not know the cause of barely any heat while driving
- The heater vent located near the feet always seems to be on......when I switch to A/C while I have the other switch on "off" it blows cool air.....no matter what I do my car is constantly blowing heat/air (which ever one I have it set on) - It's blowing heat/air equivalent to setting 1 for fan speed.
- While driving a few weeks back, I had the heat on max then all of the sudden smoke started to come out of my vents and my car acted as though it wanted to die (sputtering/missing). I thought my heater core blew but there was no liquid on my carpet or any other signs of it blowing.... this is where the problem of my heat/air being on started after this.
Old Nov 30, 2010 | 02:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Heating / Air problem here!
Sounds like it's time for a heater core. What thermostat are you running? a 160 will not allow enough heat to notice in the winter, even a 180 could be too cool depending on what your winters are like.
Old Nov 30, 2010 | 02:37 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
You're trying to say 160 degree air isn't hot? Do you know how hot Dunkin Donuts serves their coffee?
Old Nov 30, 2010 | 11:53 PM
Demo77's Avatar
Engine: 305 TBI
I think the thermostat I am running is 160.... actually I think my car runs at about 140.... It never goes past the first quarter mark on my thermostat gauge on the dash.
Also, would my heater core be the problem with my heat or air being constantly on? I think in the mayhem of the smoke and stuff, some wires were singed causing more vents being opened. I put on windshield defrost vent and the floor vents are on as well ?!
Old Dec 1, 2010 | 07:14 AM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
the smoke i bet is the blower motor on the way out.a 160 t-stat is to low for good heat,and the vent selector is vacuum operated.the temp selector is cable operated.change the stat and blower and switch .go from there.the blower on all the time should be the fan switch.
if the heater core was bad you would smell antifreeze in the car,and have a leak.
mustangman65_79
Sep 1, 2015 03:51 PM
dyeager535
Aug 28, 2015 08:10 AM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
kyle5647
Aug 15, 2015 11:56 PM
