Heat problem
Old Dec 1, 2010 | 06:19 PM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
Heat problem
I have had some problem with my heat since I added stop leak to my radiator. I have since replaced the radiator, but for the time being I had to run it with stop leak before I replace the radiator. My problem is that I have heat only when I put my foot on the throttle. When the car is idle, the car runs cold air only. Did I possibly clog the heater core. What can I do to best fix the problem? Thanx
Robert
Old Dec 2, 2010 | 12:12 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Heat problem
if the core is clogged, you should have one hot hose and one cool-ish hose. i'd definitely start there. how old is your water pump? any temp issues with the engine as well?
Old Dec 2, 2010 | 12:32 PM
TA-Rocks's Avatar
Re: Heat problem
The water pump must be original. The car runs perfectly cool in the summer and winter at the right temp. The gauge never rises over the 220 mark when idling. The fan comes on as it should.
So could the water pump be clogged also? Which water pumps are recommended for replacement on our cars, if I replace it?
Old Dec 2, 2010 | 06:48 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Heat problem
Stop leak is always a bad idea unless you are on your way to trade it in. You might have clogged the heater core, or you might just have air in the system. Check temp of both hoses as posted above. Stop leak will not clog a water pump, but I could see how when you rev it up the water is getting forced through the core.
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
mustangman65_79
Sep 1, 2015 03:51 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
chazman
Aug 22, 2015 02:01 PM
