knock sensor/cooling fan temp. switch locations 5.7L T.P.I camaro
Old Dec 4, 2010 | 03:21 AM
t-topsavage's Avatar
Car: 1988 Camaro IROC-Z/28
Engine: L98 5.7L T.P.I, stroked 383
Transmission: turbo hydro-matic 700R4
Axle/Gears: Borg Warner 9 boltG80 2.77
I need desperately mainly pictures of a Knock sensor, Knock sensor connector, Cooling fan temperature switch, and cooling fan temperature switch connector. My connectors are in bad shape hell the knock sensor isnt even connected I think or it might be the switch im not sure.. I might even have placed the two in the vise versa spots when I rebuilt the motor. Either way one has never even been hooked up. curious thing is my check engine light has never come on. but anywho if someone could help that would be awesome. Engine is an 1988 5.7L T.P.I. One connection on the harness is a pop on style the other is a slip or slide on style.. Best description I have really. Thank you.
Old Dec 4, 2010 | 03:25 AM
Re: knock sensor/cooling fan temp. switch locations 5.7L T.P.I camaro
This is what I believe is a knock sensor connector but I have seen cooling fan temperature switches that look just like it.. I dont know if I got it wrong or the stupid websites do.. I have yet to see what I describe as a slip or slide on connector how I describe it anywhere but I know it exists considering its on my damn car..
http://www.partsgeek.com/catalog/198...connector.html
Old Dec 4, 2010 | 07:55 AM
Longshot379's Avatar
Car: 88 5.7 Iroc
Cooling fan and knock sensors usually have the same plugs and are located on the passenger side of the engine. Cooling fan sensor is in the head between #6 and #8 spark plugs. The Knock Sensor is below the Fan sensor in the block right in front of the Starter. If I remember correctly, Knock sensor plug is white and the fan switch is black.
Old Dec 4, 2010 | 01:01 PM
see heres where I would say your right and thank you for your help but the problem is, on my car at least they are clearly quite different... hence my headache lol. im going to go jack my car up and take some pictures.
Old Dec 4, 2010 | 04:57 PM
Car: 88 5.7 Iroc
On my 88 5.7 TPI car ,the only slide on connector is for the temperature sender on the drivers side head.
Old May 15, 2012 | 11:58 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
wait... i thought i hooked up the knock sensor... theres two cables... this might explain why even after replacing knock sensor i still get the code.. '.' so white one is knock sensor and black is switch
Old Jun 17, 2012 | 03:26 PM
92CamaroRS-BWJ's Avatar
Car: 92 Camaro RS, duh?
Engine: 305 V8... for now...
Transmission: MAN...ual
So what will happen if the cables are swapped? Specifics, I understand it will probably run like crap.
84z96L31vortec
Aug 20, 2017 12:16 AM
db057
Aug 22, 2015 08:17 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Rustyweb7
Aug 9, 2015 03:05 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
