Cooling Hoses non AC 5.7L TPI
Old Dec 18, 2010 | 02:10 PM
AJ87CAMARO's Avatar
Car: 1987 Camaro
Engine: 5.7 TPI
I found a diagram on this site that shows were the hoses should go and see that mine are connected wrong. I have the hard line tube that goes from the heater core to radiator and would like to know if anyone has any pictures they can post on how this fits on the fender wall. Also looking to find new radiator hoses and don't want the blue ones. Where can I find black ones?
Attached Thumbnails Cooling Hoses non AC 5.7L TPI-ss850257.jpg   Cooling Hoses non AC 5.7L TPI-005.jpg
Old Dec 18, 2010 | 03:22 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Cooling Hoses non AC 5.7L TPI
The hard line goes down on the frame rail. A 90 degree angled hose comes out of heater core and down to hard line and straight heater hose from the other end to the Rad. In the middle is the fitting for the bypass hose, but I don't see the valve on your pic. Every parts store usually has black ones.
Old Dec 18, 2010 | 03:33 PM
AJ87CAMARO's Avatar
Car: 1987 Camaro
Engine: 5.7 TPI
The way the connection is now is it has a 90 degree off the water pump going into the heater core and pumped and wrong pipe on heater core. The other goes from the intake into heater core. This was a carb system before so I think the heater lines were kept the same. I just need to see how the hard line sits on fender can not get it to work not sure if the aftermarket headers are in the way will post other pics so you can see what I am working with. Thanks for your reply!
Old Dec 18, 2010 | 03:47 PM
AJ87CAMARO's Avatar
Car: 1987 Camaro
Engine: 5.7 TPI
Here is what it looks like and should it be resting on the headers like that?
Attached Thumbnails Cooling Hoses non AC 5.7L TPI-ss850659.jpg   Cooling Hoses non AC 5.7L TPI-ss850660.jpg   Cooling Hoses non AC 5.7L TPI-ss850663.jpg
Old Jan 3, 2011 | 11:24 AM
AJ87CAMARO's Avatar
Car: 1987 Camaro
Engine: 5.7 TPI
Anyone with any photos with the hard cooling line without AC or the bypass valve? It just does not seem to fit correct down the frame rail. Thank you
84z96L31vortec
Aug 20, 2017 12:16 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
