Flex Fan Question
Old Dec 22, 2010 | 08:54 PM
fireburn84's Avatar
Car: 1984 Firebird S/E
Engine: 5.0L 305 V8
Flex Fan Question
I'm thinking about getting a Flex-a lite flex fan for my 84 Firebird which has a 5.0L V8. Would anyone recommend these and should I get the 18" model or the 17" model? I've heard that they cool well but can be very loud.
Old Dec 22, 2010 | 10:20 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Flex Fan Question
years ago i tried a flex fan on my z28 while investigating
a problem with running high temps (around 230*)at
high speed in hot weather-the flex fan cured that
completely,would stay at 190 running it hard on the
highway-flex fan was pulling much more air than
ram air was providing-even at over 80 mph
(yes,air dam in place-but possibly folding under at
speed)
though noise wasn't that bad,i could hear the fan at
over about 3500 rpm and could notice a hp draw at
over 4500 rpm.
BTW the fan was a flexalite 1300 series of 18"dia.
-a halfway decent design,some flex fans have pretty
bad aerodynamics-including those cheap black plastic
ones,the blades twist and go into a partial reverse
pitch-just thrashing air while creating useless drag
What i liked about the flex fan:
-good air flow and cooling at all speeds
-little to go wrong
What i didn't like:
-HP draw at over 4500 RPM
electric and clutch fans have their own lists of
advantages and disadvantages,depending some on the
cooling situation at hand
I later put the clutch fan back on...
For a firebird shroud,17" is the right diameter.
Old Dec 22, 2010 | 11:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can't fix the clutch setup?
Old Dec 23, 2010 | 12:42 AM
fireburn84's Avatar
Engine: 5.0L 305 V8
Thank for the help. Sounds like it comes down to personal preference. I'm working on a tight budget so the flex fan is an affordable option for me. The fan I'm looking at isn't made of plastic thankfully.
Old Dec 23, 2010 | 12:47 AM
fireburn84's Avatar
Engine: 5.0L 305 V8
The fan I have is just plain worn, it looks like the blades are ready to fly off. It seemed like the flex fans were offering some good results with simple installation and low price. Naturally that made me suspicious.
Old Dec 23, 2010 | 08:49 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you're on a budget, it'll work fine. You'll lose less power with a clutch fan though.
mhatfield 14
Oct 24, 2015 07:48 AM
krisner89
Oct 10, 2015 06:03 AM
gixxer92
Sep 1, 2015 04:32 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
