Radiator cap Dry Rot?
Old Dec 28, 2010 | 12:28 AM
Guest
Guest
Posts: n/a
I replaced my radiator cap. The one before the rubber on the other one i had was dry rotted and spring didn't flex the best?
I bought a new one and put it on so i have no way of testing and also the temp would get up to 240 degrees.
But i have no way of testing and my air duct part of the paneling was hanging so getting a bigger washer or going to the junkyard and picking up a new one mine i kinda torn.
Do you think this will make it run alot cooler now.
Old Dec 28, 2010 | 04:02 AM
IndyL03's Avatar
Car: 1993 Caprice
Transmission: 4L60
Re: Radiator cap Dry Rot?
cooling system when it pressurizes it is going to find the next next weak spot- if there is anymore. you replaced to cap- old was dry rotted. if everthing else will hold up then you need to make sure to get the best air flow across the radiator.
Old Dec 28, 2010 | 11:14 AM
Guest
Guest
Posts: n/a
Ok Sounds Good But do you think this will fix my close to overheating i replaced most hoses also done the thermostat and all the good coolant flushed twice radiator is clean uhm, let's see and new coolant. Gm's 50/50
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
Stryker412
Sep 20, 2015 06:59 PM
blackandblue02
Sep 10, 2015 08:19 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
