Deleting Factory Oil Cooler... Bolt Sizes Needed
Old Dec 29, 2010 | 02:03 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
What size Hex heads do I need to remove the Oil Cooler, and what size bolts do I need to plug the radiator lines?
Old Dec 30, 2010 | 12:40 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Deleting Factory Oil Cooler... Bolt Sizes Needed
You don't need bolts to plug the lines.
just remove the complete system.
Run a new rubber coolant line from your rad strait to the hard line on the frame on the pass side of the car. This will bypass the oil cooler and lines.
PM me if you want to sell it.
Old Dec 31, 2010 | 03:33 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
i always hated the way gm setup the factory oil cooler on our cars, using coolant so close to oil is a bad idea to mean, and disaterous if somthing happens to it. and with hedman longtubes, you have to ditch it anyway, plus underhood cleans up alot with less lines everywhere.
good luck dude!
adam
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
knight72
Aug 10, 2015 09:32 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
