Tips on replacing radiator?
Old Jan 7, 2011 | 12:15 PM
dmbfan's Avatar
Car: 1984 Trans Am
Engine: 5.0
I'm replacing the radiator in my 1984 trans am. I'm puting in the same radiator as the original, just a new one. Any tips to make installation easier?
Old Jan 7, 2011 | 12:20 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: Tips on replacing radiator?
patience is key..lol..ive replaced mine 3 times for various things..
get a turkey pan to catch the coolant..
take off the rad support, unbolt the fans, un-do all hoses and lines, pull old out and put new in..
not hard, just some hard to reach places..
getting the lower rad hose off was the hardest part for me...
Old Jan 7, 2011 | 12:36 PM
dmbfan's Avatar
Car: 1984 Trans Am
Engine: 5.0
Patience is definitely not my thing but I'll try. Did you put new hoses on yours?
Old Jan 7, 2011 | 12:45 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
nah..no need unless there cracked
Old Jan 7, 2011 | 12:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Don't forget the tranny cooler lines if it's an automatic - make sure to use some PB Blaster on those fittings, and use two wrenches to keep from breaking the lines.
Old Jan 7, 2011 | 01:13 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Its easy to replace the hoses after you replace the radiator but new ones wouldnt hurt. Sometimes its hard to spot a damaged hose if its in a hard to see spot. This probably seems obsessive but while you have it out I would look for rust or just corrosion in the radiator support area. I would sand out any surface rust, primer that area, then paint it. I bought this stuff called Zero Rust and I am going to paint all underneath with that. This is just a suggestion.
Kevin
Old Jan 7, 2011 | 01:19 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Yes definately use the 2 wrenches for the transmission lines. When I was in high school twisted it inside and I got water in the trans and tranny fluid in the radiator. It was a mess and took a lot of work to get cleaned out.
1992 Trans Am
May 10, 2023 07:19 PM
Ghettobird52
Apr 21, 2020 08:44 PM
theshackle
Aug 22, 2015 06:52 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
