Pitcock Leaks
Car: 1987 Trans Am
Engine: 5.0 Liter
Pitcock Leaks
Need some help ASAP,
The radiator in my 87 305 ta has a plastic pitcock that is about 2" long with threaded diameter of stem about a quarter of an inch. When trying to find where my radiator was leaking I noticed that the pitcock was loose and would not tighten up. No matter how much I turned it, it stayed loose. It looks pretty mickey mouse. What the easiest thing to do to fix it? It's got a fork on the end of it and I'm not sure I can just put a screw in the hole...
Any advice will be appreciated!!
Thanks,
Dale
Thanks,
Dale
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Pitcock Leaks
Sometimes you have to push them into the radiator and then tighten.
Car: 1987 Trans Am
Engine: 5.0 Liter
Re: Pitcock Leaks
I appreciate the help. I bought a new pitcock today and will see tomorrow if I can get it to tighten. Things aren't made like they used to be...
Dale
Dale
