Dual Fan Mount
Old Jan 15, 2011 | 11:11 PM
VandykeT/A's Avatar
Dual Fan Mount
My 86 all ready has a single electric fan on it and I have a dual fan set up. My question is the bottom mounting bracket the same for the duals as the single set up. Thanks
Old Jan 16, 2011 | 12:05 AM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Dual Fan Mount
IIRC, I think the fans bolt on the bottom of the core support. So no bracket needed. Just need the upper shroud for a dual fan set-up.
Old Jan 16, 2011 | 09:14 AM
blackroc68's Avatar
Re: Dual Fan Mount
Yes you do need the bracket!
Old Jan 16, 2011 | 11:35 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Dual Fan Mount
What he said
Single and dual fans have their own specific upper and lower mounting brackets. You need the upper and lower bracket made for the dual fan set up to bolt the fans to
Old Jan 16, 2011 | 09:52 PM
VandykeT/A's Avatar
Re: Dual Fan Mount
Well the reason i asked is because i only have the top mount and the fans. No bottom bracket. Would it be possible to make a bottom bracket or figure out a way to rig it to work that won't fly apart within a few miles. Thanks
Old Jan 16, 2011 | 09:56 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Re: Dual Fan Mount
here ya go!
http://www.moderndaymuscle.com/inc/sdetail/775
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
