radiator cooling fan
Old Jan 20, 2011 | 03:56 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Transmission: 700r4 stock
I want to reconnect my fan switch some how the connector on the that goes on the fan switch got broken and the fan doesn't work like it should. if the metal on the end of the wire touches the block or the frame the fan comes on.
this is a rookie question but is there a way to put the plastic housing back on the wire so it will connect like it should? please help! I bought the car a year ago and believe it or not this will bring the car back up to stock and everything will work.
Old Jan 20, 2011 | 04:46 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: radiator cooling fan
Go to local parts store, and order a Dorman part number 85140 - that's the connector for the fan switch. If not Dorman, try Conduct-tite same part number. You can see it on the link below:
At top left side, change the page number to 32 - it's left page, 4th row 1st column
http://www.dormanproducts.com/flipbo...nductTite.html
Until it comes in, you can attach that wire to any metal (ground) on the car, and the fan will run (make sure it turns off with the key).
Old Jan 20, 2011 | 05:45 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
thank you your a life saver!!!!!!!!!!!
steimel94
Sep 23, 2015 12:48 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
